Changing a hole size
Last post 05-13-2008 11:19 AM by Dan B. 2 replies.
Page 1 of 1 (3 items)
  • 05-13-2008 9:11 AM
    • Dan B
    • Top 25 Contributor
    • Joined on 05-13-2008
    • Windsor Ontario
    • Posts 12
    This is probably a basic question, but I haven't run across this in any of the tutorials yet. How do you change a hole size?
    Thanks
    Dan
  • 05-13-2008 10:19 AM In reply to
    Re: Changing a hole size
    Hi Dan,
    To change a hole size you can use the pull tool.  Pull is context sensitive and works on walls, holes, cylinders, edges and pulls them to deform them or change them.  With a hole pull changes the radius.  If you have a specific diameter in mind and don't feel like typing in the diameter/2 when pulling (I usually don't), then you can Right mouse button on the hole and set the cylinder diameter.
    Best Regards,
    Roman Walsh
    Filed under: , ,
  • 05-13-2008 11:19 AM In reply to
    • Dan B
    • Windsor Ontario
    • Posts 12
     Hi Roman,
     Okay, I see this now. I had tried that, since it seemed logical, but it wasn't working out so well because the holes were chamfered. If I fill the chamfer first, I can easily resize the hole. Thanks for your help.
    Dan
