32-Bit in my 64
Last post 01-05-2009 1:16 PM by TheoE. 9 replies.
Page 1 of 1 (10 items)
  • 01-03-2009 6:18 AM
    32-Bit in my 64
     Hi guys,
    I recently got a new desktop that comes with Vista x64 installed. When I try to install SC it mentions that it does not support 64bit systems. I have an SpaceClaimLT license and knew that it was 32 bit only, but thought that it would install easily like other 32bit applications do...
    Is there a way to override this and install in 32bit mode?
    Thanks a lot.
    Have a happy new year!
    lorbus
    Filed under:
  • 01-05-2009 4:44 AM In reply to
    Re: 32-Bit in my 64
    I managed to install the demo without a problem.
    My license won't work though. SC defaults into viewer mode...
  • 01-05-2009 9:30 AM In reply to
    • TheoE
    • Top 10 Contributor
    • Joined on 11-30-2007
    • Posts 85
    Re: 32-Bit in my 64
    Hello lorbus
    In order to register your license, you will need internet access. Without a valid license, SpaceClaim will only run as a viewer.
    Please let me know if you need further information.
    Regards
    TheoE - SpaceClaim Client Services
  • 01-05-2009 10:51 AM In reply to
    Re: 32-Bit in my 64
    Hey Theo, how are you doing?
    When asked for a serial number...
    The only serial I had is the one for the old Demo. (We don't need serials, do we?)
    It now loads but with a 30 day Professional demo instead of my LT version...
    By using the license installer, I can load LT, but then it pops back into viewer mode.
    Any other ideas?
    How can we make the regular LT installer work in 64bits?
    Thanks,
    lorbus
  • 01-05-2009 11:20 AM In reply to
    • TheoE
    • Posts 85
    Re: 32-Bit in my 64
    Hello lorbus
    In the case of LT, you will need to download and install the license file from your My SpaceClaim page, this will supercede the Serial Number and when installed correctly, SpaceClaim LT should start instead of the viewer. Use the SpaceClaim Installer to install the license file.
    Regards
  • 01-05-2009 12:43 PM In reply to
    Re: 32-Bit in my 64
    Sounds good...
    The only thing is that Software Licenses comes up empty when I log on:
    Thanks for the great support Theo!
  • 01-05-2009 12:54 PM In reply to
    • TheoE
    • Posts 85
    Re: 32-Bit in my 64
    That is because your license has been assigned to Lorenzo - you should see the license file when you log in as Lorenzo.
    Regards
  • 01-05-2009 12:56 PM In reply to
    Re: 32-Bit in my 64
     Ohhh, I forgot to mention that I tried in to log in 3 different computers using 3 different browsers!
  • 01-05-2009 1:11 PM In reply to
    Re: 32-Bit in my 64
     You are right Theo...
    I mixed up two logins with the same email address. My bad.
    Sorry for the great confusion.
  • 01-05-2009 1:16 PM In reply to
    • TheoE
    • Posts 85
    Re: 32-Bit in my 64
    I assume you are all set now - let me know if you need more information.
    Also, if you have anything confidential that you would prefer not to post to the Forum, please send it via e-mail to support@spaceclaim.com.
    Regards
