Blend funtion improvement
Last post 04-08-2009 6:24 AM by josephy. 2 replies.
Page 1 of 1 (3 items)
  • 04-06-2009 11:26 AM
     When I was in the use of blend funtion, it was found that surface should not generate an increase in the guidance to adjust the curve, I do not know the follow-up will increase the blend funtion?
    Fig1.
    Fig2.  Solidworks "surface-loft" funtion
  • 04-07-2009 12:28 PM In reply to
    Re: Blend funtion improvement
     Hello josephy,
     I believe you are looking to select guide curves to influence your blend.  To do so, you must ALT-select the guides before pulling through the blend.  You can find a better explanation of this process in our tutorial section.
    I hope this helps,
    James
    Filed under: ,
  • 04-08-2009 6:24 AM In reply to
     Thanks James !!
