sheet metal
Last post 02-23-2012 12:56 PM by Paramesh. 5 replies.
Page 1 of 1 (6 items)
  • 05-24-2009 6:24 AM
    • wph
    • Top 10 Contributor
    • Joined on 08-09-2008
    • Gouda, The Netherlands
    • Posts 45
    sheet metal
    I really like to have the possibility to create mitered flanges in sheet metal. I cannot find such a function in the help files.
    Is this scheduled for future release?
    Best regards
    Willem Wagelaar
    Willem Wagelaar
  • 05-26-2009 4:18 PM In reply to
    Re: sheet metal
     Hello Willem,
    There is a tutorial in the Help that does cover this functionality called "Converting a solid to a sheet metal part" and can be found under Getting Started > Tutorials.  It walks through the workflow of starting your model as a regular solid and changing it to sheet metal afterwards.
    I've also made note that you would like to see this functionality incorporated directly into the Sheet Metal toolset.
    Filed under:
  • 01-24-2012 3:02 PM In reply to
    • KaN
    • Top 75 Contributor
    • Joined on 10-16-2010
    • Posts 4
    Re: sheet metal
      Normal 0 false false false EN-GB X-NONE AR-SA MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
    This post by Willem Wagelaar was placed in 2009 and now it is 2012, Three years have passed and spaceclaim still cannot make mitre flanges .
  • 02-04-2012 1:05 AM In reply to
    • tomnagel
    • Top 500 Contributor
    • Joined on 02-04-2012
    • 17 Halpin Ln, Ridgefield, CT 06877
    • Posts 1
    Re: sheet metal
    A lot of ebooks are available on this topic.
  • 02-04-2012 10:19 AM In reply to
    • KaN
    • Posts 4
    Re: sheet metal
     Can you please give a few examples !
  • 02-23-2012 12:56 PM In reply to
    Re: sheet metal
    hi, i'm not sure where to put this message, but i was wondering whether it was possible to convert a sheet metal part to a solid, because i want to change the colour of the face. It actually isn't a sheet metal, rather it is acrylic but sheet metal works just as well. whenever i try to change the colour of the face, it stays greyed out whereas when i right click it, it says that the colour is indeed black. it clearly isn't. it's nothing to do with my graphics card because there are other components that are black in colour (they aren't sheet metals though) thanks for trying to help
    Filed under:
