Hi Roman,
Thanks for your reply and clever tip.
I was trying to make a protrusion / pull / add on one side of the sheet-metal and the equivalent depression / push / cut on the other side, as if the metal was hit with a punch or hammer.
Using a mid-plane sketch, cutting on one side and adding on the other, is a good and fast work-around.
Nevertheless, being able to do this while keeping accurate sheet metal thickness on the edges and controlling bend properties, would have been great.
Maybe in a future revision?
Nick
