changing metal thickness
Last post 07-02-2013 2:20 AM by ABHINAV. 5 replies.
Page 1 of 1 (6 items)
  • 03-11-2012 1:11 PM
    How can I change a metal gauge after I have created the folds, bends & the unfold window?
    You can't pull the thickness.
    I have tried changing the thickness in the options panel. but it doesn't work retrospectively.
  • 03-14-2012 8:53 AM In reply to
    • vimal
    • Top 25 Contributor
    • Joined on 04-11-2011
    • Posts 33
    Re: changing metal thickness
     You can change the thickness by selecting the root component from the structure tree and chaning the thickness in the properties panel.
  • 04-04-2012 5:54 AM In reply to
    Great options to make changes in thinckness of metal.
  • 05-10-2012 7:14 AM In reply to
    • charlesshall
    • Top 500 Contributor
    • Joined on 05-10-2012
    • Lighthouse Ct Mobile, AL
    • Posts 1
    Will try changing the thinckness of metal by following the tips you provided..
  • 05-22-2013 2:17 AM In reply to
     Does anone know how to change sheet metal thickness? Is the methods you referred above can be used to do the same?
    discount designer perfume
    discount perfume
  • 07-02-2013 2:20 AM In reply to
    • ABHINAV
    • Top 75 Contributor
    • Joined on 03-28-2013
    • INDIA
    • Posts 7
    Go to SpaceClaim Options > Sheetmetal Tab > define Thickness > OK
